Toyota 4Runner 95' fuel injectors replacement
Originally I had a brown "denso" fuel injector, the correct model for my engine 3VZE (this injector has one hole CC/min-200,OHMS 1.7, lbs/HR-19.6, kPa-290)
i switched those injectors with light green "denso" injectors (he has 2 holes but I'm not sure what is the correct model here is a denso chart: http://club4ag.com/faq_and_tech_pages/Toyota_Injectors_Specs_Data_Denso.html )
I suppose the new injector has a bigger flow rate and I should Increase the amount of air entering the engine.
What do you suggest, how could I Overcome the problem? The new injector
The new denso injector
The old brown injector
The old injector
The old injector
The specs of the new injector show that the amount of fuel is bigger.
I seiches between the injectors, and now I feel that the car is heavier in the bagging of the drive.
might want to confirm you got the correct one.
the ECU expects X amount of fuel to coordinate with its programmed air/fuel/fire management.
changing one of those will throw off the curve.
