top hose hot bottom still lukewarm......
my 22r is messing with me today. driving to work temp gauge got all the way up to the top white line. so i stopped at the quickie mart to see if it was something simple. it's been down below zero for a couple days. topped off coolant and drove it another two miles. got hot again, so i sat next to the highway and let it cool down. this time started it back up temp gauge went up to where it normally runs, it warmed up a bit and then thermostat open and cooled it back down. I did hear a gurggling when I turned the heater back on. I got to work shut it down, thought i might just be a "gremlin" but on the way home, did it again. it seems to me something is freezing. as title says top hose hot, bottom warm. by no means close to the top hose. To me im thinking it's one of 3 things:
1 coolant isn't mixed correctly, stopped and bought 2 gallons of 50/50 pre mixed and am going to change it. along with a coolant flush chemical. goop is the brand.
2. thermostat. local toyota dealer don't stock the dual stat. Ideas on what I can use for time being until I can get 9016 one?
3. I just replaced the rad cap with one from autozone. I don't know the poundage, but it was the one they suggested. I don't think that would cause all of this.
You guys got any great ideas?
Thanks
Woody
Thanks
Woody
The temp difference between the two hoses is usually 'stat related, as in it is not opening. I always make sure to drop mine in hot water to open it up a few times before it goes in. Did you properly bleed all the air out of the cooling system? This can also cause hot spots. The cap should be fine if it is new.
There should be a temperature difference between the upper and lower hoses, that tells you your radiator is working. Could you tell your engine was overheating? Other than the stock gauge? You might have gotten an air pocket in the system, when the air reaches the coolant temp sensor the gauge will rise due to the air will be hotter that the coolant.
I plan on ordering another Toyota one but need the truck tomorrow. What should I get from pats house to get me by till Toyota one gets here?
Thanks
Woody
I know a lot of the guys here will say otherwise, but i wouldn't bother draining the coolant again, just put the good one in and call it good… There comes a point when its just overkill Personally, i've never had a problem with the parts store brand...
hmm thought it might be mix so drained coolant again, this time using gallon of not pre mixed and topped off with premixed. Also found a new radiator 3 core copper and put it in. now it doesn't overheat but goes all the way up to the top white line before it drops back to half. normal for non Toyota t-stat?? ?
i jacked it up on my driveway incline and let the thermostat open and close twice, both times getting all the way up to the top white line before it opened. i did not have heat at first though, so it makes me believe i had an air bubble in heater core and got that out because i had heat after the thermostat opened.
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
07-16-2015 06:20 AM
Poncho0206
07-10-2015 06:21 PM
