Timing and distributor ?s
Old 10-08-2016 | 06:19 AM
Montana22re's Avatar
So I wanted to check my timing yesterday and followed the correct procedure to do so but found that my timing is at 5 deg but my distributor is maxed out counter clockwise/all the way up to achieve that timing! Shouldn't I have some room to adjust my timing advanced or retarded once in the 5 deg setting if I wanted? Or was the distributor installed incorrectly? Sorry if my explanation isn't clear.. And and my distributor body is also cracked so I'm guessing that will need to be replaced? Just curious if to get the correct timing the distributor is to be maxed out in that direction.?
Old 10-08-2016 | 10:42 AM
muddpigg's Avatar
Sounds suspect to me. Doubt it is a tooth off but possible. More apt to think:
it's an old chain and time to replace or
block and head have been decked thus chain is a bit longer than a new engine. To change that you would need an adjustable cam gear.
how's it running?
Do you know when last time timing set was changed?
Old 10-08-2016 | 10:52 AM
Flash319's Avatar
Just pull it out and move it one tooth. Was put in like that.
Old 10-08-2016 | 11:33 AM
how's it running?
It's a rebuilt motor about 500 miles ago... I cant say for sure if the timing chain wad was done also and nor do I have the guys info aanymore...it does run very well I think but I'm new to the Toyota world. Not sure how to proceed or if i should.. Just kinda bugs me that it's maxed out to one side.
how's it running?
Old 10-08-2016 | 11:41 AM
muddpigg's Avatar
I'd bet chain was replaced at rebuild. LC engineering sales adjustable cam gear and new distros too. But like anything from LCE it's spendy. Pretty sure theirs other vendors that carry adj cam gear just can't think of them at moment.
Old 10-10-2016 | 01:58 PM
Is it just as simple as That? Can I just pull it out and turn, re time and go?
Old 10-10-2016 | 05:27 PM
muddpigg's Avatar
Give it a go.
Old 10-10-2016 | 06:42 PM
Flash319's Avatar
Yup that simple. Before doing it though, just incase you loose position, put the crank at tdc mark with the distibutor rotor point near number 1 cylinder. Mark the position that the rotor is pointing to on the distributor housing wih a black marker or something. Pull the distributor and move it one tooth. Then turn the housing so that the mark lines back up. You will now be back where you were with more adjustment.
Keegan137
03-08-2023 07:03 AM
Zpayne21
Engine Swaps
7
10-10-2016 06:54 AM
Zpayne21
09-05-2016 05:08 PM
nuknuk
08-24-2016 07:43 AM
Poppie51
08-20-2016 06:36 PM
