Terrible Gas Mileage?
Toyota 3VZ-E V6: Power of a 4 cylinder, fuel economy of a V8!
After you install the new O2 sensor, go get a tune-up. At 205,000 miles, it probably needs one. You also stated you had 31" tires, but you never said what kind. If they were like mud or all terrain tires, then your mileage will suffer a bit due to rolling resistance. Cold air intakes don't usually work unless you have a free flowing exhaust to match it. In your case, with the turbo muffler and lack of cat, there is a possibility that you could see a mileage improvement. A set of headers would help to increase exhaust flow, and in our case, decrease the likelihood of head gasket problems. However, few companies make them and they are very expensive.
To add to Kiroshu's list in post #12, replace your fuel filter. It's probably not the #1 culprit, but it wouldn't be anything but helpful.
I have the V6 and with stock gears and 32" all terrain tires, I average 16-19 mpg (after accounting for tire size). Last summer I went through a tank of gas and calculated 20.5 mpg, my best mpg ever. However, this was the time before I accounted for the larger tires. If I accounted for tire size, I really had around 21.5 - 22 mpg. So it is possible to get some fairly decent mpg out of these engines.
#27
that tells me why they are bumpy. I had a set of those tires a while back on an 86 4runner and broke belts in all 4 tires within 3 months of purchase. How does the tread wear look? I'm not saying it is your problem but it happened to me.
It didn't do anything to my mpgs but it was very very annoying.
That said, I get great gas mileage when I have my girlfriend drive us in her Cavalier lol. My 4Runner 3.slo, maybe about 14mpg on average. MUCH MUCH better with long long light throttle flat land highway excursions. Steep hills gaining in altitude from 3500-10,000 feet or tons of stoplights, brutal. Its part of the game. I still love my truck
#28
Have your timing set Properly.
But this can Only be done correctly, after your Trottle Position Censor TPS.....is set properly. This must be done!
Your new Oxygen Censor will work with the new settings and you should see an improvement in MPG.
.....carry on!....
.....carry on!....
#30
Setting the timing on mine from 12 back to 10 BTDC increased my mpg from 13-14 up to 16-17.5, with 21 highway (75mph average). It also gained a noticeable power increase.
I use Sea Foam about every 6 months.
he's gone
7
12-03-2019 07:08 AM
Tacoma1313
08-17-2015 05:44 PM
nonstop
7
08-11-2015 09:26 AM
