Temperature gauge problem
Hey so I am now having some problems with my temperature gauge, i tried searching on here but came up empty. Lately in my 95 4runner the gauge does not work. Randomly when I am driving the gauge will kick in and show that the truck is running at the right temperature then i will look back down at my gauges a couple mins later and the temperature gauge is back to 0 and not working again. What direction should i be looking into for this? should i be looking at the sending unit, the temperature gauge itself, a bad connection somewhere, or maybe thermastat going out? any help much appreciated thanks guys!
mine did the same thing. I could pound on the dash and get it to snap back to life, but got tired of that. I finally pulled the cluster out. Looked like a coke had been spilled back there. I cleaned it all up and checked all the connections. Works like it should now.
I am having the same problem too....my temperature gauge is in the middle regardless how long I am driving or when I just start the 4runner up....I hear it might be stuck thermostat....
I have read alot about this when i did my sr5 swap. And it seems that one of the solutions is a dual port thermostat available at the dealership. There is also a "fix" I came across that I want to try before buying the expensive thermo.
remove the cluster and look at the back behind the thermo gauge, there should be 3 wires connect by little brass screws. It is my understanding that if you put in 3 very small washer's behind the screws and re-connect, your gauge should fucntion normally again since your giving your screw a new surface to ground on. Now I don't think these solutions are related but if one does not work the other might..
I had the same issue. Mine would flip all around and usually it was not working at all and when it would it was right on. I discovered that the plastic between the coolant temperature sensor and where it screws into the intake was a crappy design and over time is likely to break and wobble around. I went through several parts stores searching the right sensor out and found a correct replacement at a pick your part. I pulled the intake plentum off and replaced it and a cracked vacuum tee (NOTE: When taking off all the vacuum lines make sure you know where they go back!). Once I put it all back together it worked like a charm! Part was $3 at the local yard! Also replace the intake plentum gasket when you are at it.
i was in auto zone yesterday figuring out the issue with that also, we finally came up with a match from a t100, not entirerly sure if it was the wrong one in it when i got the yota or if it really needed to be the one from a t100 but they match so ill be putting it in sat and we will see
In summmary; to fix this problem need to get a new temp sensor and the plastic piece that sits btw sensor and intake...
the1998sr5
15
07-14-2020 08:35 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Poncho0206
07-10-2015 06:21 PM
