Tachometer acting wierd
Old 04-29-2014, 04:52 PM
Rerunn's Avatar
Mine did the same thing. I removed the cluster and loosened the retightened all the screws which I'm assuming act as grounds on the flexible circuit board. Problem went away so I'm assuming that is what fixed it.
Try it it's not very hard to do. Maybe this is the cure? ?
Old 04-29-2014, 05:54 PM
superex87's Avatar
It seems in most cases smacking the tach makes it come back to life, same with the temp differences. Metal shrinks when its cold i.e. bad contact, expands when its hot i.e. makes contact. I would say its safe to assume there is a loose connection in the tach somewhere.
Old 02-08-2021, 10:54 PM
helidriver's Avatar
Originally Posted by Westicals82Toy
I have an 82 pickup with the same tach problem so I'll be looking in to the connections. I also have problems with my factory temp, oil pressure, fuel, and voltage gauges. Sometimes they work, sometimes they don't. Is it cause from the same thing? Bad connections? Low resistance? Or do I have something else going on? I just replaced some burnt fuses and re-wired my tail lights. I'm hoping something I did wasn't the cause.
i had a similar issue with all gages but speedo in my 87 4runner go dead and batter would die with the lights on while driving... apparently all on same circiut as the backup lights and i had a short at the reverse light sender at the tranny. Fix mine.
msugoose
03-02-2012 04:59 PM
CILO
10-10-2008 02:00 PM
Phssthpok
03-14-2007 02:10 AM
jsrusse11
10-27-2004 09:17 PM
Quick Reply: Tachometer acting wierd
