Sylvania Silverstar Ultras 9004/SU
With my truck being a few years old and a little lifted, my headlights are not the brightest. So I switched to the new Sylvania Silverstar Ultras. If they hadn't been on sale for $10 off, I would really be disappointed. They are only a little brighter and white-er. Not like there site shows. (Obviously there standard halogen must have been on a 50 Chevy with a 6 volt system). I would only recommed the change if you had to change a bulb from burn-out or breakage.
I almost bought these for $37 as well, but at the last minute dropped them and got the brighter sylvania 2pk for $16. After reading your post. I'm glad I didn't get them. I was also looking at the GE nighthawks for $27.
yeah, i dont care for my headlights too much either, other than replacing the bulbs, do i have to do anything. i still need to figure out how to replace them.
i am guessing the higher the number H(#) the brighter it is?
is the silverstar a good company?
Don't immedeately condemn the bulbs if you are still running the stock wiring. Test the voltage at the back of the headlights and see if light output is being limited by excessive voltage drops in the factory wires:
- http://www.4crawler.com/4x4/CheapTri...ml#VoltageTest
If you are not getting within 0.5 volts of the battery voltage at the lights, then the factory wiring is your light output limit, not the bulb.
The aftermarket bulbs, like the silverstars work alot better when you also install a heavy duty headlight harness. I had the same problem, I purchased a set of silverstars and wasn't to impressed with them. So I bought a heavy duty harness for like $17, it was all plug and play, pretty easy to install, I noticed a significant difference. Now people flash their brights at me thinking I have my brights on.
I was never impressed were Sylvania bulbs.. period, I've had the silverstars and I could tell little or no difference. Then I got some $50 dollar Hella superwhite bulbs.. all I can say about those is . But then I decided I wanted an H.I.D. look so I went with the Luminics Pure Blue for $35.. and everyone think's I've got HID's now.. haha.
Ya, let us know. I'd like to try those too. When I 1st got my truck, I put a set of these on: http://cgi.ebay.com/ebaymotors/88-91...QQcmdZViewItem I actually like them. They aren't too much brighter, but they were nice and clean vs the old ones. Oh and they are cheap!
These are nice too:
These are nice too:
So a question... With my Gen 1 and the lousy sealed beam units, can I just trade out to a set of reflectors and removable bulbs? Is there anything else I need (the HD harness sounds like a no brainer)?
zz_denis
09-06-2015 04:43 PM
justdifferentials
Just Differentials
08-15-2015 06:25 PM
crawler#976
12
11-02-2003 08:24 AM
2000, 4runner, 9004, 9004su, 9004su2, harness, headlights, silver, silverstar, silverstars, star, su, sylvania, ultras, yotatech
