Switching to synthetic
So after reading many posts i decided to rake the money and go full synthetic in the drive train. The oil of choice: Redline.
For the transmission and transfer case i got mt-90, for the diff i chose the heavyweight 75w90 gear oil, and for the engine Castrol Edge 10w30.
My only question now is how to do it?Is it necessary to drain all of the old oil, flush it, or just drain and fill? Will the redline work or break down with the old oil mixed? The transmission currently has Coastal 75w90 gear oil and the rear diff has valvoline 75w90 gear oil but as for the front diff and transfer case i have no idea since i dont ever remember my dad changing the oil in them.
I will also be installing the marlin crawler shift seats and socket along with the oil.
synthetic is suppposed to be better for everything..
but with synthetic motor oil..it WILL hurt your motor if you've been running regular Dino oil for 200,000 miles then all the sudden switch to synthetic..can't remember what it does..but it's not a recommended swap for high mileage motors..
but i have heard people gaining as much as 2mpg's from a FULL SYNTHETIC FLUID SWAP
which is more than enough for me..im puttin synthetic's in the 4runner whenever i get the motor broken in..lol
I heard in high mileage motors it can dislodge sludge around seals, mmmm instant oil leak. Then again i heard mileage does not matter. I myself have run Castrol gtx for 22 years, mm but YES synthetic does look appealing.
I run full syn in my 2++,+++ mile rig. Motor, tranny, t-case, front diff (the rear has a locker that hates anything but dino juice). I did have an oil leak for a while but it stopped when I went to a thicker syn.
Royal Purple is what I use. The first oil change after 10,000 miles was full of sludge and crap, the second one looked as good as the new oil going in. I'll run 5000 miles and swap the filter and add a half quart. 10,000 and a full swap.
I went and looked at the rig and I'm at 233,904 miles. I swapped at about 210,000. The 86 I had before I bought at 177,000(ish) and did the full synthetic swap the day after I bought it. Had to replace a front main seal (20 minute job) and had no leaks after that.
Why?
Why?
well..i guess i should have put in the post..that it doesn't ALWAYS bring up oil leaks..lol..just in some cases..hahaha
i noticed in my '80 20R that if i used a 10w30 oil..it would leak a little at a bunch of different places...but i jumped up to 20w50 (the factory recommended weight) and bango..no more leaks.............for a while..LOL
I'd rather have leaks than a sludgy engine.
If people would use the synthetic, the seals would probably stay good pretty much forever... and they wouldn't sludge.
Originally Posted by Gnarls
NO synthetic oil doesn't cause any more leaks.
My bottom end showed amazingly little wear after many years of using name brand dino oil (whatever was on sale), with oil and filter (yes, even cheapie Frams at times) changed every 3K miles. I'm thinking changing the oil regularly is as important, perhaps more so, than what type of oil you're using. Flush out the acidic byproducts from combustion, etc. I'll probably stick with dino oil after my rebuild. The lowest temps I ever encounter are above zero. If you're in truly cold climates, synthetic makes more sense.
Costwise, since synthetic is about twice the price of dino, which is better: more frequent changes of dino oil vs. running synthetic for longer intervals because it costs so much? I lean toward draining out contaminants on a more frequent basis.
I'm no expert, just throwing in my $.02.
Here's a good site for oil nerds: www.bobistheoilguy.com
Wrong. Its not going to "hurt" anything. It will lessen wear and tear, period. The complaint about synthetic is that the engine's little leaks may start up again as synthetic often cleans the engine really well, and cleans out where sludge has formed and blocked leaks. It doesn't cause new leaks and certainly doesn't damage the engine.
yeah, but unless you were using thick oils and you have sludge issues, i'd doubt that you'd see that much. I netted 0 mpg, but my engine was always clean.
not a bad idea
not a bad idea
Well, my transmission isn't the best shifting with 286,xxx miles. Plus there is cheap Coastal gear oil in it that is probably Gl-5, when it should be Gl-4.
The 286,xxx miles are not original to the engine, it was rebuilt a while back so i don't think it will hurt. I think it probably has around 40,000 actual miles.
And all i wanted to know was the process of switching since i have already ordered the oil.
but with synthetic motor oil..it WILL hurt your motor if you've been running regular Dino oil for 200,000 miles then all the sudden switch to synthetic..can't remember what it does..but it's not a recommended swap for high mileage mialege...
If you're hoping for better shifting with the syn lubed transmission you may be disappointed. When I swapped to syn on my last runner, I found there wasn't enough friction on the synchros for smooth shifting.
