The swampthing2 killed in action...
Old 04-01-2009, 09:40 AM
  #261
bigtrucknwheels's Avatar
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
Originally Posted by grant526
ST Was it running at 4k @ 70 before you started teaching your sis to drive stick?
that's a very good question haha.
Old 04-01-2009, 12:00 PM
  #262
space-junk's Avatar
i cant see any reason why teaching someone to drive would cause something like that... (not trying to be rude, grant)... me thinks something might either be low on oil the brakes are dragging...
Old 04-01-2009, 12:05 PM
  #263
flashkl's Avatar
if the clutch is shot, it would take more revs to maintain a high speed like that
Old 04-01-2009, 12:23 PM
  #264
grant526's Avatar
No problems Space-Junk. With an Auto those could effect it that way. But with a stick, the only way for engine RPM to change relative to Transmission speed is for the clutch to slip. You probably know from learning to drive stick that a beginner generally slips the clutch excessively, possibly eventually destroying it.
Old 04-01-2009, 12:52 PM
  #265
precisely!
Old 04-01-2009, 01:41 PM
  #266
SwampThing's Avatar
Nah, the taco made the same speed at the same rpm steadily since I've gotten it. The clutch isn't slipping (done the clutch test). Brakes dragging wouldn't cause the rpms to be higher than normal, the truck would just seem sluggish and seem not to have as much grunt, aside from the massive heat buildup and the smell of burnt asbestos lol.
The tcase is DEFINITELY not stuck in lo range. Lmao, you'd grenade your clutch at 40mph...
And nah, even if the truck was geared higher, lets say with 5.71s for the sake of argument, my 5th gear roadspeeds and rpms would still only be around this area:
2000rpm - 38mph
2500rpm - 48mph
3000rpm - 58mph
3500rpm - 67mph
4000rpm - 77mph
So basically, even with 5.71s, at 70mph my engine would only be at 3639rpm, NOT the 4000rpm it is currently. For me to hit 70mph at 4000rpm, with 31s, stock tcase gearing in high range of 1:1, and a stock r150f tranny with a 5th gear of 0.84, I would have to be running 6.28s in the diffs. Which, I can tell you is quite impossible. There are no such things (as far as I know) 6.28s for toyota axles.
No, I'm kind of thinking that my tach is off...
Old 04-01-2009, 01:52 PM
  #267
maybe its a 4 cylinder tach
idk. When I go home tomorrow night, I'll run the 4runner and note the RPM's I get too. I'll let you know
Old 04-01-2009, 02:12 PM
  #268
xzyragon's Avatar
Yeah, longhorns aside, Austin has it's nice way of driving me straight up the ****ing wall whenever I hit that solid line of traffic right about at slaughter lane...
And yeah, the taco will more than likely get some sort of exo lol. And as far as hanging midgets from the stinger goes, I actually found this pic when we were building. Lmao...
haha looks like something my bro would do
Old 04-01-2009, 03:47 PM
  #269
flashkl's Avatar
does it sound like youre running 4k rpms? Try downshifting to 4th next time youre on the highway, then you'll know for sure if youre spinning 2800 rpms or 4000 rpms
Old 04-01-2009, 04:03 PM
  #270
SwampThing's Avatar
^Good idea. Have to try that when I get back in town.
Old 04-01-2009, 04:36 PM
  #271
SwampThing's Avatar
And you know what... I dunno what these 3.4's are supposed to idle at, but I just remembered that mine was idling at 1200rpm. I didn't think that was normal. Seems to idle smooth as velvet though, so maybe my tach IS off... Then again I come from the diesel world, where my cummins idled at 500rpm, and none of my other toyoters ever had a tach, so I never paid it any mind. Thoughts?
Old 04-01-2009, 05:47 PM
  #272
650 or so is the idle, up to 750. I think you got yourself a bad tach.
Old 04-02-2009, 12:00 PM
  #273
grant526's Avatar
Sounds like a bad Tach! It should sound like it's reving pretty high "at idle" if it is really running at 1200+/-. I'm pretty sure you would notice and think something is wrong
Old 04-02-2009, 03:24 PM
  #274
space-junk's Avatar
hmm... thanks for the heads up grant, i forgot about the slipping clutch scenario...
Old 04-02-2009, 04:43 PM
  #275
SwampThing's Avatar
So, how do we diagnose a bad tach? Slap my multimeter on it and either ohm it out or get some voltage reading?
I was just thinking... Isn't there a pot on these that you can turn to change them from 4cyl to 6cyl like you can do with the 86-95 sr5 cluster swap?
Think I remember reading something once that when people would swap the sr5 cluster out of a 3vze into their 22r/e, they would have to make some adjustment for it to count the 4cyl revs correctly? Cause what I'm thinking is if it's something like that, maybe that pot got turned somehow, and now it's thinking it's reading like a 4cyl, thus displaying a higher rpm.
Make any sense, or should I take off my brain storming hat?
Old 04-02-2009, 09:20 PM
  #276
haha, nice hat.
I got you some numbers today;
55MPH = 2100 RPM
60MPH = 2250 RPM
65MPH = 2400 RPM
Yes, you are correct about the potentiometer. Here is a thread about that: Thread About SR5 cluster swap
Last edited by bigtrucknwheels; 04-02-2009 at 09:39 PM. Reason: corrected data entry. ha.
Old 04-03-2009, 03:43 AM
  #277
SwampThing's Avatar
Awesome thank bro. Life saver! At lease now I know I don't have complete brain damage... Now I just gotta find a thread that still has pictures in it of that pot.
Old 04-03-2009, 06:59 AM
  #278
those pictures were recently removed. I just checked that thread out a month ago and they were there... Sorry about that. I have a spare cluster out in the garage, maybe tonight I can tear it apart and snap a picture for you so you know what you're looking at.
Old 04-03-2009, 01:18 PM
  #279
SwampThing's Avatar
Love you long time?
Old 04-03-2009, 02:55 PM
  #280
Junkers88's Avatar
One day when that child that asked his mom why there are endangered species is going to grow up and ask.
"Dad, why can't I find an older Toyota that hasn't been killed?"
His dad is going to respond.
"Son....... Clint has been wearing his thinking cap for a loooong time and those older Toyota's can run far enough."
Quick Reply: The swampthing2 killed in action...
