Suspension lift options
#61
What do you mean when you say the front suspension is shot and needs to be replaced? Most lift kits won't replace any ware parts. They just reposition what you have. If you have worn out or damaged parts, I would fix safety issues first.
That being said, new leafs in the rear and bj spacers up front. A slight lift for that beefier stance, with spending alot or having to change a bunch of other things too. I know I have a 4Runner but hear's what mine looks like with 1.5"-2" lift with 31x10.50's.
![](http://www.jamesdeancreations.com/4Runner/Suspension/Front%20Stance%20Lifted.jpg)
#62
the shocks are toast all the way around and i needed new leaf springs in the rear... also, ball joints or wheel bearings up front. im putting new ball joints in anyways and will do wheel bearings if needed when i have it apart.
#63
That 4 drawer Craftsman toolbox is the greatest. Throw in a set of pliers and some srewdrivers and your set. I have one in every vehicle I own. I've never broke down without having the tool I needed to fix it and go.
#65
#66
Frank
#67
Is there a shock in particular you'd like to know about? I have researched quite a few. If you want, maybe throw up a shock length post and myself and others can populate it with information. There is shock length info on this bbs but it's fairly spread about among threads.
Frank
Frank
#68
How did this work out?
How much did it run you?
How big of a pain was it to install?
Any pics?
Thanks
#70
1 Post
This question may seem dumb to those of you with experience, but I'm pretty new to this sort of thing, and was wondering if the steering damper is necessary with a ball joint spacer lift?
#71
Yep, you need it. It really has nothing to do with the lift but with the larger tire diameter. Also, wheeling in general applies more force to the tires and an aged stock damper will usually leave you wanting a newer one with more damping.
Frank
Frank
09-04-2015 09:27 AM
94ofCanada
08-14-2015 06:37 AM
coffey50
07-28-2015 10:55 AM
Vargntucson
07-04-2015 12:15 PM
