strawberry milk in tranny!!
Ok...so I went out wheelin last night, and got myself into a real deep hole, it didnt look that bad untill i got into it, and wouldnt ya know it, the water ended up coming over my hood, any way long story short, I got it out and running, however there is still some water in my tranny, What would be the best thing to do at this point..other than the obvious(Flush it out, new filter etc) do you think that will be enough, or am i going to be looking for a new tranny? thanks in advance.
O... also It sat for about 6 hrs in the hole, and was only driven about 8 miles to get home. and I DO have pics.. ill post the links later on!
From what I've heard it takes a lot of flushing. Might want to start flushing with some cheap ATF since it will likely take multible flushes. Each flush can take up to 15 qts of ATF so the $$$ can add up fast. But I'm no expert.
Most of the others I've seen have been radiator ATF coolers that failed and the tranny was filled with coolant. Not sure which is worse The dirt in muddy water could be worse I guess.
Your water was probably sucked in the breather vents or through the dip stick joint.
Good luck
Good luck
it actually drove and shifted normal, im gonna do the flush myself, the nearest shop is 30 miles away, so grab 3 times the amount of fluid...maybe i be ok? I hope so, already did this a few years ago, and ended up having to replace the tranny, didnt know there was water in it for almost 2 weeks tho, any additives that may help? Thanks for the quick responses
heres a link to a pic on my friends myspace, just to give an idea of how bad it was, my g/f and i ended up lighting a fire and sleepin on the ground till daylight!! what great fun!!lol
http://viewmorepics.myspace.com/inde...ageID=31239956
sorry guys....it worked for me yesterday, but i guess because i was still logged in...Ill try to find another way to post them, it was nasty, water up to the gear shifter in my truck!! and to make matters worse it was a jeep wrangler that pulled me out
And had I thought the hole was as deep, I wouldnt even have tried, but I have taken this trail many times, and its never been like that.. I hear some guys with 37+ inch tires have been going through and tearing it up.
ok, dried the ecm out, I'm getting spark at the plugs, and i can smeel the fuel...so i know its getting both, but still wont start...I dont get it...started and ran fine after when i drove it home yesterday, now it wont fire... is there something i might be missing? any advice is welcomed.
Here is the link to the new thread:
https://www.yotatech.com/forums/f116...rt-now-143875/
LOL...Yeah..liquid balls (guiness).. worst part was having to make my g/f sleep on the ground next to a fire till daylight... it was cold...and she got cranky quick... she laughs about it now though!!
TheBFA
02-15-2020 07:55 AM
live4soccer7
05-11-2016 07:52 PM
hiluxinargentina
09-30-2015 06:51 PM
