Straight Axle price
I dont know about the longs i finally broke down and bought them but i only broke 2 birfs in 3 years and both times i was a little under the influence while wheeling (if you know what i mean) and it always seemed like more throttle was the answer but you will be alright if you lay aff the skinny peddle until you get them
#27
drinking and driving is never cool and not the best t mention on a public forum..please be careful its not just your life you may end.
but i do agree lay off the skinny pedal and bring a trail spare youll be aight
#28
Definitely worth it to expense yourself out for upgrading to longs unless you have access to free spare parts.
#30
#31
I plan to upgrade to longfields, but at the moment, once i get the axle under the truck, im going to stick with birfs for a bit, well at least give them a try
only on 33's for now
#35
well trail gear has some i guess or FROR
http://frontrangeoffroadfab.com/nfos...0e24e66f32a6b0
http://trail-gear.com/knuckle-service.html
I might order from Front Range Offroad because they have the nuts and studs where TG only has Studs i think
#37
http://www.wabfab.org/products/frontaxle/frontaxle.htm
Personally, I don't like the FROR mechanical lock nuts as they have been known to strip out the studs if you have to remove them. No reason not to just reuse the OEM nuts/washers/cone washers.
#40
Chromoly Steering Arm Studs
oh yea? Well thats good to know.
