SR5 convertion
SR5 convertion
i have a standard pickup that i'm converting to a sr5, it has a tach cluster installed. the tach does not work and the temp gauge does not work correctly. how do i fix the tach?
i have a inclino too. how do i get the lights and stuff to work? where do i splice them into the system? the light behind the heater control panel does not work and a clock has no hookup, how do i get all this stuff working.
You should get the wiring diagrams for the donor vehicle plus the vehicle the cluster is going to be installed in so you can trace wires. I'm installing an SR5 cluster from a '91 V6 4Runner into my '89 V6 Xtra Cab, and from looking at the wiring diagrams some wires will need to be moved to different places in the connector.
The tach works off of a wire coming from the igniter. You may have to tap into one of the wires at the igniter and run that wire to the tach.
If you don't have FSMs, you can probably find them here:
https://www.yotatech.com/forums/f116...umbers-102344/
129Creepin
08-05-2015 10:12 PM
Esibnitsud
07-30-2015 08:19 PM
crashburnoveride
07-10-2015 06:39 AM
