Spindle bearing/bushing part?
I am having difficulty sourcing these parts outside the dealerships. Has anyone found these parts for a good price. Also has anyone had a fuel pump failure? Looking at doing some preventative maintenance, and a new fuel pump sounds like a good option for my 1990 3.0.
Quoted from this thread
https://www.yotatech.com/forums/show...3&page=2&pp=25
"Just wanted to let anyone know if you're planning on doing it the replacement bearings are NSK #DB503011 needle roller bearings. They are 37 mm o.d., 30 mm i.d. and 19 mm long. I found the 'stealership' price for the bearings very high so I'm passing on this info for anyone who wants to try getting them at a bearing supply place. Don't know if you can but may be worth a shot. The new inner bushings were cheap, and probably a dealer only item."
I think he is referring to the new inner spindle needle bearing that Toyota changed from the original brass bushing. They are very expensive at the dealer. The outer spindle bushing remains as a brass bushing. These are different than the front wheel bearings. Thanks eric-the-red !!!!
FS[GreatLakes]: 22RE performance and stock parts (pic heavy)
05-20-2016 10:27 AM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
