Something is bent?
Something is bent?
I have a 94 4x4 pickup. The drivers front wheel is pushed rearward an inch. Truck pulls hard left. I am not sure what would cause this. I am about to swap out Tre's, ball joints(top and bottom) pitman arm and idler arm and center link. All at the recommendation of the alignment shop. They may all need changed but i dont see how it could fix my issue. I read a post about bent LCA brackets but i dont know how to check if they are... any suspension wizards care to help a newb out?
Could just be the adjuster on the lower control arm turned max one direction. Or that the little bracket that it rides in broke. Did you hit anything? Pot hole, tree, pedestrian?
Im sure someone hit something at some time. Of course the "family" member who borrowed it didnt hit anything... i have looked underneath for anything bent or out of place but i am yet to find where its at. It does look like the lca rear cam adjust bolt could be adjusted to push the rear out. If i take it in for an alignment do u think it could be resolved?
YT Community Team
The following users liked this post:
Andy A (03-14-2020)
- Slipped LCA alignment cams/bolts
- bad LCA and/or UCA bushings
- bent LCA or UCA. (Those parts are very difficult to bend unless you were in a wreck.)
- bent frame
A combination of slipped LCA alignment bolts and bad bushings could add up to an inch of wheel motion. That works out to about a 4 deg change in caster, and I think the alignment cams have about that much range. By the way, that 1 inch rearward position is almost certainly the cause of your pull. 4 deg of caster mismatch would be huge, and the vehicle will always pull to the side with the lowest caster (most rearward wheel position given our geometries).
Definitely start with the LCA cams and bushings.
old87yota (03-12-2020)
Same thing happened to my 87 4Runner after hitting a bad ditch on one side 4-wheeling. Alignment shop adjusted control arm as far as it could go and truck did ride straight after that, but one wheel was always further back. Everything was replaced on that side over time, including upper & lower control arms, but wheel was always further back on that side. I attributed it to a slightly bent frame. Truck was only 2 months old when I did the damage
FInd another shop. None of those parts will move the wheel forward or back at all, they'll just affect toe and steering tightness. The wheel position is set by the LCA and UCA, and the LCA alignment bolts. Most likely causes of your issues are:
- bent frame
- bent frame
the only reason that an alignment shop could get away with their recommendation that you replace all of those parts before they do an alignment is if there is play in them or they are trying to sell you on "the alignment will last longer if you start with new parts".
A good alignment tech will tell you if anything is bent and if anything has play and needs replacing before they can lock down the alignment. if you were to replace any parts after the alignment has been done then you should do another alignment so if anything is questionable replace it now.
Thank u. I already have the parts so im putting them all on so i know what ive got. Taking it to a different alignment shop after i install the parts
