So I Bought an '86 for $1000...
#41
http://www.drivewire.com/make/cat/gr...-cover/toyota/
Ranging from 1.39-18.60
I'll try the grease first though see how that goes. You think any kind of grease would do? If you don't mind will you let me know the specifics for the kind you have been using successfully?
Thanks again, super helpful.
#42
If you want a good ride still and capability you should look into the blazeland Kit. and you wont have to spend $5000 to build what you want. http://www.blazeland.us/
Thanks. Great info.
#43
Check this thread out. https://www.yotatech.com/forums/f116...inding-238600/
If you look under there I bet this is what you'll see or maybe even worse. This is likely the cause of that noise. It does sound terrible but it's normal.
montanatruck
02-26-2017 07:07 AM
WellsR
12
07-31-2015 03:27 PM
