setting distributor timing
PROBLEM SOLVED: yes, the o2 sensor wire was the cause. once fixed, no more fuse blowouts and its back on the road and running.
that suggestion saved me much grief and thanks again. looks like that is a common issue that can blow your efi fuse!
