Runnin rich after Oil Change
So my dad changed the oil in my brothers 94 toyota pickup mated to an auto tranny. After a little wile the thing started blowing black smoke and idles rough to none at all. All that was done was the oil change and all the fluids were checked. I know its running rich but what could cause this i dont know what to fix or what to check
How many miles between the oil change?
a friend of mine went without changing oil for 20K+ miles and experienced the same problems after finally changing the oil.
check engine light on? pull the battery cables for a bit to reset the ecu, then try and run it and see what happens...is it blue or black or white smoke, maybe you have a headgasket issue...
So, what engine? 22re? It may be possible that, when changing the oil filter, a sensor plugin was unplugged, or a wire was broken, if one of these was a temperature sender wire it may cause the problem you're having. Or it may be unrelated to the oil change, did it happen directly after, the the moment it was fired up? Or did it gradually come in. Could be lots of things, any more info?
Not exactly sure but my dad says it happened after the oil change and he didnt do anything as i said before this is the 3vze hooked to a auto tranny
The truck is pouring black smoke and runs like crap. No plugs were touched only fluids were checked
jasonty
41
12-23-2018 01:00 PM
