runnin on 3 out of 4 cylinders....
#41
and now for the fun-
the 22re injectors are all wired in parallel- all 4 fire at the same time.
If you switch say #2 and #3 injector plugs (they should reach) the problem should follow the plug from #2 to #3 if it's a wiring problem, or stay on #2 if its the injector... or something more mechanical like a sticking or mal-adjusted valve in #2.
"Noid" lights are great trouble shooters here too since they will reveal if the injector is getting a signal. No "flash" of the noid, no signal.
#43
the ECU has two injector outputs. the wiring harness connects those two outputs together so all injectors fire at the same time, once per engine revolution, but twice per cycle. almost like Toyota was trying for a more precise engine management system but stepped backwards to get it certified. As a compromise, one pulse per engine revolution would require injectors rated for 1/2 the flow per interval since the injectors would deliver 100% of the fuel required and be able to deliver 50% of the fuel with each crankshaft revolution.
Not sure if that makes sense....
#44
i was just recently told that they fire in pairs... i dont know who or what to believe... but ill switch the connectors and see what happens and ill post my findings when i get them
#46
alright fellows.... im sorry for bein suck a complete dip and a pain, but the problem has been found... it was a missing connection in the harness where the injector wires meet and split, i reconnected the wires charged the battery abit, it fired up on three cylinders and i got worried that i screwed up, a few seconds later it evened out, now i just need to final tune it and ill be set once again.... so thank you all for your help and puttin up with my idiotic self....
#47
now i got a new problem... but i did narrow it down to a vacum leak at the egr valve.... i dont know whether or not this will fix it but ill try... basically i took it for a small run, the idle was erratic and it tends to sputter... can this all be caused by the egr leaking??
