Rough Idle and hissing noise problem.
Old 02-16-2016 | 01:29 PM
Crazychris1871's Avatar
I'm stumped folks. I have a 1989 pickup 3.0 V6 3Vze engine with 4x4. I recently tore into it due to an oil leak, I replaced the rear camshaft plugs, front cam seals, and the front crankshaft seal. While I had it all apart I installed a new water pump, timing belt, tension pulley, and the top pulley between the 2 can gears (not sure what it's called) I also replaced the plugs, wires, distributor cap, and rotor. Now my issue is I can start the truck and it will run great until it gets up to operating temperature. Then it idles rough and will eventually die out. I have a hissing noise that sounds like its coming from under the plenum and a decent amount of smoke or steam as well. I have no idea where to start to try and fix this issue. I have a short video of it running rough if anyone would like to see it.
Antonio Cadiz
7
02-11-2016 02:15 PM
goofybud16
02-06-2016 02:29 PM
pyrojoe22
Engine Swaps
01-31-2016 07:20 PM
predatornpink
01-29-2016 06:20 AM
mortievondee
01-19-2016 01:44 PM
