Rim Seized to Axle?
this happened to a guy in my shop class with a jeep truck, he was hitting on it for 20 min. with a sledge before it came off, you might try some penetrating oil on it because its better to get it free now than get a flat somewhere and not be able to change your tire.
I was able to remove the starter without removing the wheel ...thanks for all the advice but so far all I got is a sore knee ...I need to get a real big hammer ... Unfortunately the starter problem is still not solved ...the solenoid clicks but the starter doesn't turn. I checked the cable and there seems to be a lot of juice at the starter so it must be a ground or a switch somewhere. Any ideas?
I solved the starter problem ...the solenoid connector was loose during the install.
I gave up on the tire ...decided to worry about when I have a flat in the middle of nowhere when its forty below ... It actually moved back when I tightened the wheel nuts so I'm thinking it was wedged halfway on?
The new starter is a bit smaller than the old one and removing and installing it is fairly easy... even with the tire on.
1uzRunner
63
11-10-2018 03:58 PM
Jamie4runner2000
06-20-2016 09:13 AM
