replacing shocks
replacing shocks
Hey, I recently had one of my old crappy shocks actually rust off. This has prompted me to replace all my front and rear shocks. Does anyone have any advice or information to give me about doing it myself?
(I'm kind of a newbie with working on automobiles)
Please search before you get flamed. The link below will get you started on the right path.
https://www.yotatech.com/forums/f129/beginners-thoughts-body-suspension-lift-tires-81122/
its very easy. Each shock has one upper and one lower bolt holding it in. Get those out and your clear to install the new ones. Soak the bolts in WD40 or similar to make it easier or just cut them out as stated.
You may need a sawzall for the top of the rears. Cut just above the lower washer, kinda through the rubber bushing and the stud. Believe it or not, there is just enough room for you to get a ratchet in there to tighten them up.
My advice is to try and unbolt them, but don't spend too much time. If it won't go, just cut them off.
It's a pretty easy job, no worries.
I had to use a pneumatic cutting wheel to get my rear shocks off. The nut rusted real bad, then stripped. I actually had to cut the nut off the shock.
I second the strap though to hold the shock. But if you don't care about the old ones, a pair of big channel locks work great.
Originally Posted by Tacoma Dude
Try to spray some PB Blaster a day in advance before the actual work. Its a pretty good penetrant and will make getting bolts out easier on you.
Roy
TURBOrunnerNM
07-22-2015 11:01 AM
rushw
07-18-2015 01:46 PM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
