Replacing input shaft on a w56
Replacing input shaft on a g52
Hey y'all,
Attempting to pull my input shaft bearing (three prong bearing puller) I broke the tip of my input shaft (uughh). Just ordered a new one from Cobra Transmission ($73.99 great deal!).
Has anyone replaced one of these? I have no transmission experience, I'm already over budget.
Let me know,
Thanks!
-Jackson
Let me know,
Thanks!
-Jackson
I was able to get it removed but have not been able to come up with a press to get it back on this might help some. https://www.yotatech.com/forums/f199...l#post52177328 I would like to see what you come up with on getting it back on.
Terry I think he needs to replace the whole input shaft and not just the bearing if that's the case then bad news I think you need to dissemble the whole transmission to remove the input shaft because it wont clear the counter shaft. When I replaced my input bearing I used a long 2 jaw puller to remove and a piece of scrap pipe just the right size with a press to install the new bearing.
I need my eyes checked, I missed where he broke the tip off of the shaft of the transmission. I have looked at about trying to rebuild a transmission but by the time I bought the replacement parts, it looked to me like you were better off just buying a new transmission.
854x4...I tried to press a new bearing on and was afraid I was putting to much pressure on the whole shaft/transmission so stopped at that point. I have a spare transmission and am planning to wait til winter when it is real cold and heat the bearing in the oven and see if it will go on easier. Did it take you a lot of pressure to get it on?
Hey guy's, thanks for the advice. Turns out I've got a g52 tranny, and I haven't been able to find any used ones, only rebuilt, and the cheapest has been $800. That said I decided to go for it, taking it apart wasn't bad at all, just frightening, for those deciding to take on this procedure themselves, feel free to PM me.
As for the bearing, it's true, that #$%&er goes on tight. Since I was replacing the shaft as well, I just flipped the shaft around and used a puller to pull it on while I tapped on the inner race from the other side using a piece of PVC. I understand this probably won't help those trying to replace just this bearing, but if your other option is a new tranny, might as well take the 1-1.5h to pull 5th gear and drop the cluster gear.
irv
05-01-2016 04:19 PM
Stuarrt
04-19-2016 10:49 AM
