Replacing fuel injectors connectors ?
yea i do.. I was going to use a C_Clamp or my vice. I was think of a way to protect the pintal cap while doing it. I see you have already addressed this. I'm stealing your idea.
Why not send your injectors out for a professional cleaning . I sent mine here and they flow test them, clean them, then flow test again and give you a before/after comparison chart after .Plus send them back with all the necessary o-rings, and pintle caps to put them back in. Turn around time was quick.
http://cruzinperformance.com/fuelinj.html
#25
After i ran them the cleaning fluid was pristine. I have never ran cheap gas.
#26
Ok that are all done and back in the truck. problem is I need to get this thing running and safety inspected. My new plugs are not here yet. Well it cause a problem is i put a little bit of RTV at the out side base of the injector plug to hold the connector on for a week or so?
It should be easy to remove when the connectors get here.
#29
I had zip-ties holding the connectors for years. It does work. Most zip-ties will embrittle at those temperatures, but it takes years.
You're not holding much force; just loop the zip-tie over the point at the base of the injector where it gets narrower.
#30
This should be ok for a while right?
#31
sorry to bring up a slightly old thread.
i replaced my injector connectors. i had the same originals that you have. the wire lock in the connector is a pain, and is virtually impossible to remove with the plenum still installed. fact is, i broke off the wires and part of the connector because i got tired of not being able to remove them easily. i ran it for about 8 months that way with no injector operation issues. they never loosened, and i checked the "fit" every two weeks or so.
the replacement pigtails, although looked down upon by some, work fine. i like the design of the ones i chose - they are EASY to unclip from the injectors with the plenum installed (and everything else). i don't have to disassemble anything to unplug them now. the new pigtail/connector provides a positive solid lock. mine happened to be purchased from Injector Repair LLC in NY. [Jetronic/EV1 Female Connector Type A #4].
wally
wally
#32
No problem:
I got the replacements but they are still in the box from the mail man.
Mine are working for now as well. I don't want to push any problems. So i'm holding off until I need to fix them or i'm working in that area.
steve miller
10-10-2015 01:40 AM
TURBOrunnerNM
07-22-2015 11:01 AM
