Replaced Idle Air Control and still have a 2700rpm idle
coolant temp sensor for the ecu?
It's the only way the ECU knows at what temperature the engine is operating.
Once the ECU knows that; it controls, timing, idle, injector pulse length, etc.
It and the o2 sensor are probably the 2 sensors that the ECU relies on the most to set the parameters for proper engine operation.
#25
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
ok update i got the idle smoothed out now. I think it was the IACV, yesterday was the first full day with it, it did it in the morning and then was great on the way home. Today idle was good all morning, I am wondering if the IAC need to break in or something. So far so good.
I have a new coolant temp sensor I am going to install once my new throttle body comes in and is cleaned up and done right, I will throw that in.
I thought about the intake being cracked, but now I have had two consistant days with the idle back a 900rpm, I think I figured the problem out.
#26
Since it is coming and going I would think you just have air in the coolent system, or worst case your head gasket is going and you are pumping air into the system (I have had this happen). Run the truck for a long time with the rad cap off to make sure that the air is out. Since you had the IACV off it may be having a hard time getting the air out. These engines are know for air everywhere.
#27
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
