replaced drivers mirror now bad angle?
Old 03-24-2016 | 08:07 PM
Smaay's Avatar
I replaced the drivers mirror with a KOOL-VUE TY31EL mirror.
figured out what wires matched up to the factory harness to get it to move properly. got it all mounted, closed the door and the angle is waaay off.
its angled inward too much and i cant adjust it out near enough to make it useful....
im pretty sure i installed it all right. what did I do wrong?
oh, 93 4runner 4X4
Old 03-25-2016 | 01:19 AM
wyoming9's Avatar
Red face
How much do you need to be able to use it ??
Is the mirror folded out all the way??****As these fold in for tight garages
This is a direct replacement made for your 4Runner .
If it is not able to adjust to your needs talk to the vendor you bought it from.
Boxed wrong in this day and age happens all to often.
If you bought this used and you have no other options you may be able to shim the mirror out enough to make it work.
Missing spacer perhaps ??
Old 03-25-2016 | 11:59 AM
scope103's Avatar
Yes, it is a folding mirror. Check that first!
Old 03-25-2016 | 04:16 PM
Smaay's Avatar
I ended up taking both units apart and using the OEM mounting hardware on the new unit. it was a pain in the ass. I had to compress the spring with a vice and C clamp. i should have taken pictures. If i have to do the same with the passenger side i will.
if you compared the new unit to the old where it mounts to the door. Its obviously not angled right, something like 20 degrees inward.
Old 03-25-2016 | 05:22 PM
wyoming9's Avatar
Red face
So you have no idea if you have the wrong mirrors
For sure they are not for your vehicle.
Old 03-26-2016 | 02:47 PM
Smaay's Avatar
the box says 90-95 4runner. but you are correct, I have no idea. I emailed the vendor and gave them the same spiel. they were very helpful but since i took everything all apart, its all moot now.
Old 03-27-2016 | 01:13 AM
tj884Rdlx's Avatar
If you got it mounted and you like it, that's all that matters. Nice job, MacGyver!
Old 03-27-2016 | 02:39 PM
Smaay's Avatar
i defiantly MacGyvered it. I really should have taken pics. just in case someone else runs into this.
msane99
03-12-2016 03:21 AM
Yont283
03-09-2016 05:33 AM
your-real-dad
Engine Swaps
02-24-2016 11:44 AM
