replace piston rings with head gasket repair?
truck: 3vze 4x4
i don't have the original engine but i did a compression test at 160k miles and and got about 170 psi before i did a valve adjustment. 20k miles later i need a new head gasket. i don't think it makes since to do a complete rebuild, i think i might want to replace the rings while the heads are off. (thoughts?) i was thinking is it possible to lower the front differential and take out the oil pan instead of taking out engine block to replace rings, then just use a flex hone with block still in. maybe it wont take longer? thoughts and opinions?
If your oil consumption was minimal, you probably will get plenty more engine life without replacing the rings.
I recently did a headgasket job on my '95 3vz at 140,000.
I thought about re-ringing but my engine ran well before, so I left it alone.
I have re-ringed several 22r type engines with their blocks in frame, but never a 3vz yet.
If the pistons are out, no reason not to replace the connecting rod bearing shells at that time. Those are inexpensive.
I think it would be difficult, if not impossible, to replace 3vz main bearing shells with the block in frame because all the main bearing caps are cast into a single reinforcing girdle.
Let us know what you decide, and how your repair work turns out!!
YT Community Team
Granted, the engine compartment looks busy, but it's not a hard engine to pull. There's some stuff you'll need to get out of the way, but shoot, most of that comes off anyway when the heads are removed.
I would do a leak down test on the cylinders before head removal. That's good info to have. Once you pull the heads and can do a visual, combined with what you learned from the leak down test you can form a cohesive game plan
well this certainly isn't just a scratch
cylinder with crack
Is this something a machinist could weld then grind away without changing bore dimensions? or would it need a sleeve? or is the block trash? the crack doesn't go all the way down the bore. seems to be just the inside of the bore with the crack. the head gasket seating area seems fine. if i left it alone i wonder if this problem is going to grow over time until i burn coolant through the crack or loose compression?
YT Community Team
YT Community Team
Doesn’t matter. Was just curious if that would have shown in the test. Test results give you a direction when nothing is obvious during disassembly. This crack would over ride any test result.
Odd crack, can’t recall ever seeing that. Doesn’t look like overheating caused it. Freeze?
YT Community Team
I doubt the cross over had anything to do with it. Design flaws like that would have meant that huge numbers of 3vze blocks would have cracked just like yours, and I haven't seen that.
Where did that engine come from?
One possibility is the crack has been there for awhile, and hadn't yet caused an issue. It was a problem waiting to happen. Is #1 cylinder where the gasket failed?
The following users liked this post:
old87yota (04-03-2022)
Ok so i was totally convinced that the block had a crack because of how jagged it looked and because of how it extended all the way past the ring wear area. But i took it to a machinist and had it magnafluxed and found out it isn't a crack. So i got the engine put all back together and it lives again. Thanks for all your assistance everyone
old87yota (04-20-2022)
i’m really curious what it was, then. it sure looks like a crack. fwiw, last year i took the head from my 3-53 detroit to a machine shop to try to find the crack that was allowing coolant to get into the air box. magnafluxing it showed no crack, but when the shop started milling it, the crack became obvious.
I replaced bearings for crank and rods. First compression ring i took out had a smaller end gap than the new pre gapped ring i got. But the second compression ring that i took out had a much bigger gap than the new one. Strange...(I only looked at one piston set) So i replaced all piston rings. Truck idles lower than it ever could.
Hi:
Don't you think that a scratch would be almost perfectly vertical?
I mean that how could a piston, which rides vertically in a bore, cause a wavering scratch like that.
That is a crack, plain and simple. If it were a scratch there would certainly be more than one.
I am of the opinion that reusing that block, sleeved or not, is a false economy that will come back to haunt you.
I wish you luck.
Art.
P.S. It is usually hole #6 that suffers because of crossover heat.
I wish you luck.
Art.
millball (04-27-2022)
mattbatson
25
06-26-2015 10:33 AM
watchesnboats
02-10-2009 05:33 PM
