Repairing corrosion in engine block coolant passages?
Old 06-27-2018 | 04:02 PM
akwheeler's Avatar
Originally Posted by Aure
Thanks for rename the topic more pertinent👍
Also, Sorry for the confusion with the heads photos. It is screenshots from internet to show the welding process to fix coolant passage corroded. Did you ever heard about cold welding with a mig on cast iron? A mate could borrow me the machine, I thought I could do it myself after learning properly how to do.
It takes some people decades to become good welders, and I assume that "cold welding" is not common so it's something a good welder would take time to learn.
You will also have to have a machine shop re-deck the block when you are done, so start adding up costs and make your choice.
Old 06-27-2018 | 04:13 PM
SomedayJ's Avatar
Originally Posted by se7enine
i'm not saying take it to a machine shop but it certainly is a question for a machine shop don't you think?
+ 1
Old 06-27-2018 | 11:56 PM
wyoming9's Avatar
Red face
First why not try see if it seals ?? You have nothing to lose but gaskets and time
If you attempt to weld this the block needs to be machined back to a flat a level surface $$$
***Explain this Cold welding I might know it under another name??
Any filler metal has to match as close as possible the base metal so the thermal cycling matches ( Which means it expands and contracts at the same rate or very close)
Most Cast Steel and Cast Iron needs a pre and Post heat
amamike91
03-01-2019 06:12 PM
az4x4runner
06-30-2018 06:16 AM
mefizto
06-18-2018 02:17 AM
‘93Beater
06-15-2018 05:05 PM
Charles4x4
7
06-01-2018 10:04 AM
Quick Reply: Repairing corrosion in engine block coolant passages?
