Removing fan clutch in a 22RE??
Old 08-17-2016 | 08:56 PM
artemyk's Avatar
I'm in the middle of a head gasket change on a 22RE. I can't seem to get the fan clutch off . I got the nuts of the bolts that connect the fan clutch "base" to the pulley, but the base seems welded onto the pulley or something. I've wacked it with a rubber mallet and it hasn't budged. Is this normal? Is there some trick to getting it off?
Old 08-18-2016 | 01:21 AM
wyoming9's Avatar
Some can be quite stubborn !!
The penetrating spray of choice let sit for some time .
using a piece of soft metal a few taps with a hammer might break it loose.
It more then likely has been on a while
Old 08-18-2016 | 06:19 AM
Flash319's Avatar
Ya they sit in a pocket and they are size for size plus corrosion.
Old 08-18-2016 | 07:20 AM
lalojamesliz's Avatar
I'm about to do a timing chain job
What area needs to get sprayed down?
Old 08-18-2016 | 09:59 AM
4RunnerFreak12's Avatar
The pulley that attaches the fan to the water pump. You may not need to mine came off easily but different climates can mean more difficult time getting it removed.
You have much bigger things to worry about like loosen crank bolt before anything else, don't forget the "hidden bolt" labeling everything and making sure to keep track of every bolt for timing cover- make card board template they must go back in correct location. See what happens when they are wrong...
https://www.yotatech.com/forums/f116...arnage-296318/
Good luck
87tyota77
04-22-2020 08:00 AM
mad_sb
07-02-2016 07:47 AM
coopster
06-02-2016 07:08 PM
dickensyota
05-28-2016 01:46 AM
subaruwrx88011
05-27-2016 04:54 PM
