rear window troble
rear window troble
so about 4 weeks ago me and friend decided to c what roof bolts complete the circuit for the rear window so i dint have to screw them all back in when i had to through the cap on quick well i found the bolts and the window rolled up and then i rolled it back down to put the roof on and since then i haven't seen my rear window haha i believe it is the rear hatch sensor does any one know where that is located it would be a great help it is getting wet back there thanks it is a 1988 4runner
The cover top switch is the first bolt hole behind the rear wheel. The switch is engaged by one of the bolts touching it. If the pin is up, the rear motor is disabled.
thanks! i cut out the switch in th back of now till i get the rest of the truck sorted out and the window goes up and down fine now now only if the truck ran haha
06-01-2021 01:51 PM
sabine
07-18-2015 03:59 PM
icentropy
07-14-2015 10:23 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
