Rear tires lean in at the top
No it won't.
If both tires are truly leaning in at the top, you most likely have a seriously bent axle housing.
I guess its possible that worn axle bearings could play a part, but they likely would fail before long, and you'd know.
It's not really bad on the passenger side it's just a little bit hardly noticeable the drivers side it's pretty easy to tell
put the rear end up on blocks, and spin the rear tires, if there is a bent axle shaft it should show up as a wobbling wheel??
i just today noticed that both of my rear tires have more wear on the outside half of the thread than on the inside :-0 never seen that one before.
A bent housing should be pretty easy to see.
That would be the only thing that would cause the wheels to be in the same position.
bent axle shaft or even bad bearing would cause a wobble in the wheel when looked at from the rear or front.
Wouldn't have thought you could even tow something heavy enough to bend the axles with the 3.0. I looked at full float conversions before - http://frontrangeoffroadfab.com/full...er-conversion/ - but decided against it for that reason.
My dad used it to pull bass boats for 15 years and it blew a gasket a few months ago and when I got it back from the shop it's had problems with the rear end since 3rd member was loose as hell u joints went bad leakin like crazy idk why
That's what I was thinking the head gasket on the motor they rebuilt blew after 19K and they redid my dads about 10 years ago and they took his radiator out and put it in his own vehicle and put the bad one in his and it overheated so much he sold it only reason I went there because it's all I could afford
06-01-2021 01:51 PM
crashburnoveride
07-10-2015 06:39 AM
