Rear ends
Old 01-03-2016 | 09:59 AM
creedua's Avatar
Rear ends
Will rear from 91 truck fit under 95 4 runner
Old 01-03-2016 | 11:32 AM
wyoming9's Avatar
Red face
Sort of if you change all the Suspension hard points around.
Fire up the welder and the compressor and Air Arc ( plasma if you have it)
the parts you no longer need
One is a leaf spring Suspension and one is a coil spring at least when they left the dealer the first time.
Old 01-03-2016 | 12:16 PM
creedua's Avatar
Could I just change 3rd member
Old 01-03-2016 | 01:47 PM
dropzone's Avatar
Fossilized
^^yes--> as long as the gear ratio matches
Old 01-03-2016 | 02:14 PM
MudHippy's Avatar
^^And it has/doesn't have ABS. Depending on which is/isn't required.
Marc
10
12-28-2015 02:08 PM
mj928
11-07-2015 11:45 PM
Gunnar Kristjansson
11-04-2015 03:33 PM
edgar62902
9
10-15-2015 12:30 PM
skouba
10-10-2015 06:15 AM
