Rear Differential; Spins After Pinion Seal Change.
Old 11-07-2015 | 05:22 PM
mj928's Avatar
89 4runner V6 Auto.
With the auto box in park and the rear drive shaft locked, I can spin the wheels. There seems to be no load on the diff.
FYI. I just replaced the rear Differential pinion seal. If it is relevant, I also did a rear brake service.
What am I doing wrong? Your help is appreciated. Michael
Old 11-07-2015 | 06:39 PM
millball's Avatar
Normal, if open carrier differential, and both rear wheels off the ground.
When you spin one wheel, the other should turn the opposite direction.
Old 11-07-2015 | 09:51 PM
mj928's Avatar
Thanks millball. Yes, wheels are off the ground and they spin opposite directions. Thanks man!
Old 11-07-2015 | 10:01 PM
dropzone's Avatar
Fossilized
Nice job of explaining your symptoms and recent work done..that is a nice change instead of going through multiple posts trying to read someone's mind
Old 11-07-2015 | 10:45 PM
mj928's Avatar
8_9_runner
11-02-2015 09:23 AM
Zeb8806
10-30-2015 05:51 PM
Deeraholic
10-12-2015 08:58 AM
user 82300
09-22-2015 07:00 AM
flg8r22
08-30-2015 10:59 AM
Quick Reply: Rear Differential; Spins After Pinion Seal Change.
