reading codes
reading codes
After completing my replacement of my head gasket, ill drive around the block and after about 2 minutes my check engine light will come on. I looked here on how to check the codes (http://www.off-road.com/toyota/tech/codes/index.html) it says there should be a 4.5 delay between single digit codes and a 2.5 second delay between double digit codes. When i checked mine it flashed 12 times one right after the other, over and over. Any ideas? this is on a 22re.
Thanks,
Tom
Thanks,
Tom
