Random Surge/Chug/Power Loss?
Hi all, long time lurker here.. I have been searching the forums like crazy the last few weeks and I have to say thanks to all there is some awesome info available here!
I have a '93 4Runner 3.0L V6 (3VZ-E) manual and I've been hunting the strangest problem over the last few weeks. Now and again my truck develops a strange surge. If I'm driving at say 60-70kph in top gear when I accelerate slightly It starts to surge? If I keep the pedal in the same place the surge gets gradualy worse and eventualy turns into a harsh chug! While it's doing this If I nail it (Full throttle) the surge goes and the car accelerates ok. It kind of feels like the timing is retarded and the car wont make any power.
I have tried a number of things:
New fuel filter - Same problem.
Fuel treatment. I thought I may have got some bad fuel - No Change.
Replaced plugs, leads and rotor - same problem.
Cleaned the throttle body and reset the TPS. Car seems to go better but still have the problem?
If anyone can point me in the right direction I would be very greatful!
Cheers
Craig.
Cheers
Craig.
jump the t and e1 connectors on the diagnostic plug with a piece of wire or paper clip. the check engine light will flash the codes according to the number of flashes with the amount of time between the flashes. check the emissions section of the online fsm here.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Ok.. I've got some codes!
1st: Code 24 - Air intake temprature sensor signal.
2nd: Code 41 - Throttle position sensor signal.
**EDIT**
After resetting the computer and driving the car for 20 minutes I have a clear diag? How long should it take before anything is reported?
Thanks again
Craig.
**EDIT**
Thanks again
Craig.
Ok, I'm back.
This weekend I to put a few KM's on the car after the computer reset. After about 150 km highway driving it started it's surge/power loss again. Though, this time it was doing it in 3rd, 4th or 5th anywhere between 1500 and 3000 rpm!?!
When I got home I thought I'd check the codes and......... NOTHING! What would make it surge and carry on like this that wouldn't register as a problem? Help Please!
Thanks
Craig.
Thanks
Craig.
My 97 was doing exactly the same thing - hesitation at 3-3.5K RPM, 3rd & 4th gear..... Fixed yesterday; was a bad throttle position sensor causing 99% of the problem. The K&N filter was in need of a cleaning as was my mass airflow filter!
i wouldnt replace it without adjusting and testing it first
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Ok. So I disconnected the TPS and went out for a drive last night.. The car is running perfectly! More power, no surging, nothing.
My question is why do I even need the TPS? What is the benefit of having it connected if it's such a PITA?
Cheers.
Cheers.
As far as MPG/HP, no difference either way really.
charlie_fong
09-27-2015 10:06 PM
