R150 Trans Pulling Hard Left in 4WD
Old 12-20-2013 | 09:35 PM
Cadin's Avatar
"Even if your transmission and tcase were twisting to the side you wouldn't get a pulling because your driveshaft would simply compensate for the new angle. Sounds like a problem with loose or worn out parts (bushings or tie rods)."
x2
What about bearings and or setting your drag on the front end , would that cause it to pull?
Old 12-21-2013 | 11:54 AM
Austin Marr's Avatar
SO the problem.......whoever the D bag was that did the diff work last (before I owned it) did not put the 2 mounting bolts on the diff when they put it back together. So my driver side diff mount is not bolted to the diff. Shocked my CV boots aren't torn. Called toyota up and had em order those two bolts
Old 12-21-2013 | 12:16 PM
wyoming9's Avatar
Red face
I guess you don`t get under your truck to often!!
I would think it would have been easy to see.
Old 12-21-2013 | 12:35 PM
haven't even touched the CVs been neglecting the IFS, trying to break it so I can SAS ;D buuuut that's not gonna happen so the overhaul it is!
Old 12-21-2013 | 12:40 PM
  #25
combatcarl's Avatar
I hear ya. That's kinda my plan. SFA is just simpler. Fewer parts.
Sent from my NSA screened iPhone
Old 12-21-2013 | 12:55 PM
  #26
HAH! Love your signature! I have a SFA that I started to rebuild but a baby came and you can't hardly fit a car seat in the cab so the truck is gonna have to go after 7 years of owning it. Gonna get a 1-2 year old 4-door taco
Sent from my iPad using YotaTech
Old 12-21-2013 | 07:15 PM
  #27
combatcarl's Avatar
Thanks, and that's a bummer. They have a section here for those, though. Don't go far, now.
mskalmus
05-28-2017 07:51 AM
andrewtexas123
07-14-2015 04:29 AM
TokyoD23
07-12-2015 06:01 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: R150 Trans Pulling Hard Left in 4WD
