Pulling engine-leave trans and transfer case attached?
I am doing a complete overhaul of my '89 Runner. I have most of the truck disassembled. When pulling the engine, can I leave the transmission and transfer case attached, and bring it out as one big unit?
It's a 22-RE with an auto-trans.
Thanks,
Roy
Thanks,
Roy
im doing that with my 3vze. you just need a load leveler thingie (to tilt the motor/trans unit) and enough over head space that you can get the arm of the lift high enough. (which was the problem i ran into when i pulled mine as a whole unit)
I Just Put A New 22re In My 90 Toyota I Left The Trans In The Truck It I Can Do It Woth A Manual You Can Do It With A Auto I Was Pretty Easy. Less Work To The Only Hard Part Is Getting The CranK To Seat In The Trans.
Poncho0206
07-10-2015 06:21 PM
crashburnoveride
07-10-2015 06:39 AM
