Pulled intake manifold to connect knock sensor, running horrible now
Not sure what you mean by "the timing mark keeps spinning"? Its possible that the keyway holding the harmonic balancer on has sheared off which would make your timing mark dance all over the place. That would be my guess on that if this is what you mean by "keeps spinning". The "loom" is just the plastic cover that protects and keeps your wires. Also double check that your firing order is correct, the right plug wires going to the correct cylinder in relation to the distributor.
While all 6 injectors fire at the same time, they are wired into two banks of three. ("#10" and "#20"). If plug-wire testing really produces the pattern you described, it sure sounds like a problem in the #10 wire to the 1-3-5 injectors (or the output of the ECM, but much more likely just a wiring issue).
Im gonna get a noid light and check the injectors today. And the timing mark moves counter clock wise around the harmonic balancer. It never sets still like it should.
a timing light only tells you that the plug wire is getting charge at top dead center of the #1 cylinder, it doesnt know if fuel is actually present. So assuming your doing it right, most have a alligator clip that goes to the positive battery connector and you clip the other lead to the #1 plug wire and the timing mark should stay in one spot, if its not either your keyway is sheared on the harmonic balancer, or your distributor is shot, or firing order is plugged in wrong.
#25
Another question, did you remove the distributor when you pulled the intake? If so this could be the issue, if it didnt get set back in correctly it will cause bad timing. The rotor has to be in the correct position with #1 cylinder at TDC.
#26
I didn't remove the distributor but not saying it wasn't messed up when I got the truck. I am thinking its the distributor more and more. After today I will know if it's injectors or timing
#27
So this evening I checked the fuel injector with a noid light and they are all firing. Put new seals on the injectors and tested the whole vaccum system and intake with a smoke machine and found no leaks. All new plugs and checked compression on all cyclinders and were all around 165 or 170. At this point I am lost. Next I guess I'm gonna order a new ditributor and hope that's the problem.
#28
#29
So with it running on 3 cyclindrs I took it to a friend that's a mechanic. He checked everything on the fire side and it all checked out good. Think it is just a coincidence that when I was cleaning up the injectors when I had the intake off that I clogged three of them. Out of options and ideas and listening to my friend I ordered a set of injectors. Hopefully this gets me running!
#30
the timing mark is supposed to spin. you need a timing light.
a "loom" is a wiring loom; a bundle of wrapped wires. in this application, it goes from one side of the engine to the other between the valve cover ends & the timing belt cover.
http://htftp.offroadsz.com/marinhake...90injector.pdf
you should definitely take advantage of these:
http://www.ether3al.com/93fsm-mobile
http://tacoma.site40.net/4Runner_90-...l/contents.htm
#31
Need to still check the tps. I'm not stupid I am using a timing light but the mark just keeps jumping around the harmonic balancer counter clockwise. The cold start injector hooks right to the fuel rail and the fuel lines are pretty self explanatory the way they run. Got the loom straight earlier in the post but thanks for that and the other sites
#32
Sorry I am not a good as some of the other seem at dechipering typographical errors and auto correct gone wrong..
You have spark at all six plugs? Injector signals are there also? Double triple check the firing order?
#33
I'm not clear how you went from "running rich, burns my eyes" to I'm not getting combustion the injectors must be clogged, to ordering parts with out testing the ones you had any of the times you've had them out?.
Grab a manual at the local parts store, or poke around online for a factory service manual. It's way cheaper than throwing parts at it and hoping and less frustrating.
In short if you can blow thru the injector it's stuck open and gonna leak, if you don't read a closed circuit between the terminals it's fried the wires and not going to open.
Hmm a simple to overlook thing would be the ground strap I guess but I didn't thing you went that deep, and even with out one on the head there are other less direct paths for the plugs to fire/ground
#34
So finally I fixed it. When I pulled the intake I never took the timing belt cover off so I didn't see that when I pulled the tensioner pulley off that bolts to the intake that the valve timing jumped about 5 teeth off. Set the valve timing and runs perfect. Thank you all for the help!
