Ps idler pulley bolt
So I'm finishing up bringing everything over from my old motor to my new motor and can't figure this out. The idler pulley from what I can see online is supposed to have a bolt through the bracket and into a threaded hole on the back of the pulley. Is this correct? Mine has a hole in the bracket not threaded and then just a nut on the back of the pulley. How's this setup supposed to work and what do I need to do about it. Thanks.
Do you have a picture of what you have?
Mine looks like the one you describe you seeing online, with the pulley looking like this: https://www.yotashop.com/toyota-4run...ey-4435035010/
It's the same exact bolt as the 4 that bolt that bracket to the block under the dizzy...
you could just pull one of those 4 is over kill on that bracket.
So far as I can tell, it's just an ordinary (flange head) bolt. If I had to guess, M10-1.25 x 100mm or so. Take the pulley down to your local Ace hardware, and ask for their assortment of metric bolts. Very carefully try an M10-1.25 to see if it fits. (The 100mm is really a WAG; try measuring how much throw you need first.)
greenmw
10
10-02-2017 12:23 PM
