procomp steering stabilizer
If you don't notice a difference you might want to check out some of your other steering components. My steering has been pretty bad and loose feeling and the Pro Comp stabilizer didn't make a difference. Turns out my idler arm bushing needs replacing and there is a lot of play in my pitman arm joint...
Well i guess ill buy one, hopefully that will help. its got new outer tie rod ends, need upper balljoints, and looks like pitman arm, it looks shot.
then ill get an alignment after the ball joints and see how it goes
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
scott90
10-04-2015 09:21 AM
