Preference for O2 Sensor Brand?
Originally Posted by midiwall
...and if there're two, then that's the front one.
Originally Posted by LS1Steve
there are two on mine, only the front though? even if BOTH are original from 215k miles ago??
The rear one has no effect on how the engine runs... It's only there as a comparison point to check how well the cat is working. If/when it finally fails, then the ECU will think that the cat has problems.
Originally Posted by kyler
anybody know where to get an inexpensive o2 sensor for a 99 tacoma v6? Is it the same as the one above? Thanks.
URD will beat the dealer...
http://www.urdusa.com/product_info.p...s_id=430006000
Find your year & engine on the list - pay attention to if you're a CA emissions truck.
DO NOT USE A GENERIC SENSOR. It won't work and/or it won't last.
#25
Well, if the ECU isn't complaining about the rear one, then save yourself $90 and leave it where it is.
i guess it makes no sense then to replace the rear. but should I replace the front after so many miles even if i'm not getting trouble codes?
#26
well technically the ecu isn't complaining about anything, i was just told that if I replace them (since they are so old) i'd improve mileage.
What I'm getting at is that "Given that we're talking about 16 years and 215,000 miles, it can't _hurt_", but it may not change anything either.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
Lonny007
01-16-2004 11:59 PM
Mohamed
06-20-2002 10:42 AM
