Powertrax No-Slip Info
I was sent the same e-mail, but it said "30 days", and that was 3 months ago. I ain't holding my breath.
What is the consensus on the LockRight, is it garbage? They're pretty well regarded from people that own them, but they're not Toyotas. I really don't want to try and track down a 4cyl diff when I just put in a rebuilt regeared 6cyl diff.
I have heard that they are almost identical off-road, except the on-road characteristics of the no-slip are better. They are supposedly smoother and quieter than the LockRight. I saw on a website, the lock right and the no-slip parts laying next to each other and it appeared that the no-slip had extra pieces in side of it to help smooth it out.
Here is my reply from Bill at Aussie from today when I asked if he had any info on the production status of the V6 Aussie:
"Not really. A discussion with the factory a few days ago indicated that they had the Chrysler 8.25 through production and New Product Manufacturing was now focusing on getting the V6 done. We suspect that they have the turning complete and are now making the axle gears and then will do the cam gears. So, if we are right, we are looking at 4-5 weeks."
SO - hopefully, it will actually happen. I'd really prefer an Aussie over a LockRight, so I am going to give it another month or two before I go with another option. I will say this, they have been REALLY quick about answering e-mails, and I haven't gotten a canned form response yet.
My experience with Lockrights has been pretty limited, and only with domestic trucks. I know a few people who have them and couldn't be happier, and I have a friend who went through 3 that broke one after another. I think that they may have been failures due to the installer, though, he was installing them himself and wasn't the most mechanically inclined.
#25
Oh, I've run welded/spooled diffs many times, and it ain't too bad. It's definitely an option, but I'm not too keen on welding up this new diff, and if I'm going to spend $150 on a spool, I might as well spend $220 and get a lunchbox locker.
#26
dont mean to bump
So is there a difference between the lockright and the powertrax...? I'm trying to get one of these on ebay right now....total cost is $246.00 new in the box.
-Ted
-Ted
#27
Powertrax is to Lock Right as Toyota is to 4Runner.
Powertrax makes the LockRight and the No Slip. No Slip is smoother, quieter and better-mannered but more expensive and only available for the 4 cyl diff.
#28
Matt16
Great. Thanks for clearing that up. The seller from ebay emailed the paypal invoice so this is going to be a Christmas present to myself.
Dont mean to hijack the thread...
-Ted
-Ted
#29
Here's the visual difference between 4cyl and v6. Determine the axle ratio with the axle code on the door jam/ bulkhead.
http://home.4x4wire.com/erik/diffs/
#30
No.
Allthough I don't disagree with you, I have to add that reading the door jams may not be correct either. The only true way is the pinion paint. You could goto the pick n pull and get what you think (according to the ID tag) is a "4.10:1" and may be a 4.56:1. So what I am saying is confirm....
#31
TheBFA
02-15-2020 06:55 AM
buckz6319
08-05-2017 03:50 AM
dirk89
10-01-2015 05:15 PM
