Power door lock switch
Can anyone troubleshoot an 89 (1st gen) power door lock switch. It's an all in one assembly with the window switches. The switch operates only to unlock the doors, not lock them. Please help. Any plausible solutions.
You might want to try this: see if the switch itself works by testing it with a multimeter. Put the multimeter in continuity mode. You should get continuity when the switch is in lock position.
Hope this helps.
Hope this helps.
ok, forgive me. what points do you connect to the multimeter (black to what connector, red to what connector) Sorry
Hope this helps.
Hope this helps.
Your contacts might be a little carboned up and dirty. Every year or so i have to open up my control panel and shine up the contacts under the switches. I use a real fine grit sandpaper. Im not sure about the 1st generation 4runners, but my panel has tiny black springs in it, so if you do open it up--do it carefully, in a well lit area.Nothing like crawling around the driveway with a flashlight, looking for something that small.
06-01-2021 01:51 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
01-16-2016 06:38 PM
icentropy
07-14-2015 10:23 AM
Johntom240
7
07-13-2015 12:18 AM
skoti89
07-08-2015 12:05 AM
