Polishing my intake - ocd can help sometimes lol
#26
haha those are cool i wonder how the a-bat would do offroad i wish they would just bring back the gen3 trucks and give em more power and economy that would be awweessome but i gues the majority like the big bubble trucks haha
#31
I'm guilty too... And as TN said, it gets all crappy looking after about a month. I'd try to strip all the grease off of it with some acetone and spray clear on it if I were you. Once the engine is put together you won't be able to do it.
#32
well hell, before paint, both my upper and lower manifold's looked quite similar; but of course I only have a pre-paint pic of my lower manifold
you wanna talk about something that's a PITA to clean...
granted it's not polished, but it still takes a long time...
and they turned out like so:
#33
haha yeah i can still see the casting surface dimples and stuff, mine is a lil smoother lol so it shouldnt collect so much dirt and stuff i hope. i almost just sanded the letters completely off because it was a pita to sand and polish all around them, i did take off the double ridge part though......right where the flat part in the middle meets the part where the letters are
#34
i still neeed the inside cleaned, i think ima take it to a machine shop for that but idk i got most of the larger deposits out so idk how much the rest will effect the performance. there was like 1/3 of an inch of buildup where the egr comes in
#35
What about the build up on the inside? Can that be cleaned up a bit on the truck or will debris falling down into the lower part and eventually into the cumbustion chamber do any damage? I just took off my throttle body to clean it up and address the TPS.
I couldn't believe what I found behind it. Its like thick, moist brownie residue stuck to the pan. Comes off with the finger but I want to spray some throttle body cleaner in there and see metal again. Is this a good idea?
#36
Idk I would take it off to clean it. But some tb cleaner can't hurt really, I would use that but don't go. Scrapin away, there's a lot o stuff in there. But even with it off its near impossible to get all that out. Its all just exhaust deposits. Uuugggh.
#40
was that to mee? i wanted to get my heads ported and get o/s valves but i couldnt justify 850$ for like 10 hp maybe. it just aint worth it, ima be fine withe headers and cams i think. eventuall im get a 3.4 so i just want my 3.0 to last untill i can do that...i might do some gasket matching though. would just use a dremel with an aluminum oxide grinder ? or i could prob use a drill
