plans for tomorrow...
Old 11-08-2008 | 05:08 PM
iamsuperbleeder's Avatar
And I was planning on just taking the day to relax and not do anything... Today I changed my oil and did a little tune-up and fluid check, then drove back up to the parts store to get rid of the old oil there; got to look'n around, and ended up buying gauges, the gauge pod, new t-stat, and a new oil pressure sencor along with the parts to make this little trick setup here so I can hook up both the OEM sensor and the new one on the pillar:
I've been wanting some gauges for a while anyway...
It'll take a little trimming to fit good to the pillar, but it's definately doable and I'll post the pics up of the final result!
Old 11-08-2008 | 05:13 PM
scuba's Avatar
Fail!!!!!
jk !!
Sounds good, Pics when its done im sure are already planned !!!
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Well, so much for relaxin and doin nothing, then.......lol
Old 11-08-2008 | 05:14 PM
freddy's Avatar
cool!!
Old 11-08-2008 | 05:17 PM
Originally Posted by freddy
cool!!
gauges are like switches; you can never have too many... the more you have, the more it feels like your sitting in a fighter cockpit
Old 11-08-2008 | 05:20 PM
abecedarian's Avatar
Sounds like a plan.
Old 11-08-2008 | 05:22 PM
Oh, I almost forgot to ask.
Is the t-stat housing a perfectly fine place to drill and tap and install the temp gauges probe?
I figured I could do that while I have it off to install the new t-stat...
Old 11-08-2008 | 06:51 PM
Jay351's Avatar
Damn you! I have wanted one of those 3 guage apillar pods for so long now. I wish I had enough cash.
Post more pictures up!
Where did you get it anyways?
Old 11-08-2008 | 07:34 PM
BigBluePile's Avatar
I figured I could do that will I have it off to install the new t-stat...
I wouldn't, but that's me. What I did was cut the upper rad hose in sections and put a sender there. Like and idiot I paid LC Engineering for that hose manifold when I could have made one for cheaper.
http://www.toyotacatalog.net/m1webge...0-5C22F7B2AACD
I also have a three guage a-pillar pod and I really like it. I have oil, water, and vacuum. They're all electric guages with green back lighting to match the rest of the lights and it has it's own light switch just like my clinometer/altimeter.
Old 11-08-2008 | 08:14 PM
I wouldn't, but that's me...
do you think it would cause any harm?
IIRC, the outlet is aluminum, and that may be the only problem, but I dunno, that may not make a difference at all anyway...
Jay, I just picked it up from my old job Advance Auto Parts; it was $40, as were the set of 3 guages... I had some extra cash handy, so I thought "eh, why not"... Plus, I don't like just having idiot lights and a needle between "L" and "H"; I want to know my volts, oil pressure, and temp fairly accurately
Old 11-08-2008 | 08:20 PM
You could, but the walls might be a little thin to mount the sender.
Old 11-08-2008 | 08:22 PM
hmm, didn't think about that...
Old 11-08-2008 | 08:58 PM
you could always get a bung welded in there!
Old 11-08-2008 | 09:23 PM
what do you think would happen if I were to just drill and tap it as is?
I mean, I'm not so much worried of it pushing out or leaking; the only caution I think I would need to take is to make sure I don't over tighten the probe when threading it on so that I do not split the housing itself around the hole...
Anyone ever tapped in with a temp gauge probe here, or seen it done?
Old 11-08-2008 | 09:29 PM
If the walls are too thin it wont seat right and it'll fit loose which will leak/spray. The sender has pretty corse threads.
Old 11-09-2008 | 07:25 AM
true about that...
I dunno, it's tapered quite a bit as you work the way up the adapter, so I think it would seal pretty well...
We'll see. I'm going to go start the install now, and once I pull the t-stat housing off to replace the t-stat, I'll make my decision after looking over it with all your reponces in mind
thanks man, I'll let you know what happens!
Old 11-09-2008 | 07:29 AM
sweet, throw up some pics and good luck!
Old 11-09-2008 | 08:00 AM
c'mon...
it's noon there. where's the pics?
Old 11-09-2008 | 08:19 AM
Originally Posted by abecedarian
c'mon...
Yeah, what he said!!!
Old 11-09-2008 | 10:04 AM
lol, ok fine, here's the progress so far...
got the guages installed with the lights and volt meter hooked up, and ran the temp probe and oil pressure tube under the hood...
but right now I gotta run up to the store and get a union for the hose, cause they never give you enough tubing for the oil pressure guage
Quick Reply: plans for tomorrow...
