Pedal bracket assembly diagram, reassembly instructions
Old 09-01-2024, 11:08 AM
mefizto's Avatar
Greetings all,
I have re-welded and reinforced the bracket, but cannot find anywhere in the FSM a diagram with assembly/reassembly instructions. If anyone could point me to the correct section or other resource, I would appreciate it.
Kindest regards,
M
Old 09-01-2024, 01:02 PM
aztoyman's Avatar
I have a pedal bracket assembly off an 86 truck in my garage I can use as a reference. What do you need to know?
Old 09-01-2024, 04:23 PM
mefizto's Avatar
Hi aztoyman,
thank you for the reply.
essentially I have the bracket, the pedals, and a bag of parts, but I do not know, how to re-assemble it, as my computer helpfully ate all the pictures that I had taken during the disassembly. So, I was hoping to find an assembly instruction in the FSM, but regardless what keyword I use, I cannot find it.
Perhaps if you could take several high resolution pictures from different angles, I could figure it out from there.
Kindest regards,
M
Old 09-02-2024, 07:05 AM
aztoyman's Avatar
The following users liked this post:
mefizto (09-03-2024)
Old 09-03-2024, 09:40 AM
mefizto's Avatar
Hi aztoyman,
thank you for the reply. This is exactly what I needed.
Where did you find it?
Kindest regards,
M
Old 09-03-2024, 10:59 AM
aztoyman's Avatar
You can usually find these parts diagrams on the OEM parts sites. Try PartSouq or Amayama
Old 09-03-2024, 12:17 PM
mefizto's Avatar
Hi aztoyman,
thank you again.
Kindest regards,
M
Old 09-11-2024, 03:19 AM
AmeliaTurner's Avatar
Thank you so much for the information.
Thomas Reynolds
07-13-2017 07:09 PM
mldave
08-31-2012 08:38 PM
absentimental
11-05-2009 09:05 PM
fordsnrebels
07-19-2009 03:53 PM
Quick Reply: Pedal bracket assembly diagram, reassembly instructions
