Passenger door window '84 4Runner
Old 10-28-2017 | 03:01 PM
slimyota's Avatar
I have an '85 4Runner and my window stopped working from the passenger door only. Driver door can put it up or down. I replaced the switch and made sure the connections work.
What is the solution here???
Old 10-28-2017 | 03:14 PM
scope103's Avatar
On my '94, there is a switch in the driver's side to "lock" the switch on the passenger side (so it won't work). Make sure that switch (if you have it) is in the right position.
Otherwise, you need to work with a multimeter. Technically, that's the only way to "make sure the connections work."
You might get better responses in a different forum: https://www.yotatech.com/forums/f115/
Old 10-28-2017 | 03:17 PM
slimyota's Avatar
'85 4Runner doesn't have that luxury
Old 10-29-2017 | 12:21 AM
wyoming9's Avatar
Red face
New switch you mean New from Toyota ??
You checked the old switch and that had failed ??
checked the new switch that it worked like it should ??
wrenchtech
50
09-08-2019 01:18 AM
RustRunner89
07-13-2018 10:01 PM
mrvictory1999
10-18-2017 01:25 PM
slacker
10-17-2017 05:44 PM
hi808guy
10-01-2017 09:15 AM
Quick Reply: Passenger door window '84 4Runner
