Part # or Source for glass weatherstrip?
I can find the glass "sweep" weather strips for the my door (1988 Pickup with side vents) but Im specfically looking for the weather stripping where the sides and top of the glass sit when the window is closed. P/O tried using some silicone to glue it back together and Id like to clean up the appearance a little. Not exactly sure what the proper name is to search for when looking up a replacement and havent been able to find a Toyota part number for it.
I believe this is the part you are looking for:
That part is called the window channel run.
It looks like both doors use the same part number, and is still available.
RUN, FRONT DOOR GLASS (with vent windows)
Toyota Part number: 68141-89108
This does not include the seal around the vent window itself, as that is a different seal (and is discontinued...)
The following users liked this post:
SomedayJ (07-25-2020)
Ah awesome thank you so much! That looks like it. Whenever I searched I could only find the door seal weatherstrip and I think when looking at the diagrams that was what I assumed it was pointing to as well.
Cebby
09-30-2004 04:29 AM
