Painted the campershell
Old 06-01-2010 | 03:58 AM
iselloil's Avatar
Talking Painted the campershell
After reading some post about painting the trucks with rollers,I decided to do my camper shell to match my truck.I bought the interluxe topside polyureathane from Jamestown distributors.Instead of rolling I went to Harbor freight and bought a gravity feed low pressure paint gun. It was $39.00 on sale this weekend.Sanded the shell with a Dewalt electric DA sander with 220 grit.Wipe it down with lacquer thinner, and sprayed the top.
Thinned out the paint with 10% thinner,and went to town.The topper used 1/4 of a quart of paint and turned out great.The interluxe is self leveling.I am going back and wet sand it then buff, but great finish for inexpensive paint.
Old 06-01-2010 | 04:04 AM
TinMan's Avatar
Pics?
Old 06-01-2010 | 04:13 AM
iselloil's Avatar
The wife has the camera in Tenn.I'll get them on tonight.
Old 06-01-2010 | 07:24 AM
phildelfino's Avatar
Do you have a model # on that sprayer?
Old 06-01-2010 | 08:57 AM
InternetRoadkill's Avatar
You need the gun that's rated for heavy-bodied primers. I think it's the one with the 1.8mm tip.
Old 06-01-2010 | 09:28 AM
iselloil's Avatar
Here is the link.Read the instructions.The pressure gauge stopped working right away, but I regulated my compressor to 45 lbs.I then ran thinner thru the gun to set the pattern,then paint.Some orange peel, but for a quick job it will do.I'll wet sand it one time then buff it.I'll add pics tonight.
http://www.harborfreight.com/high-vo...gun-66222.html
Old 06-02-2010 | 05:01 PM
iselloil's Avatar
I cant get the pictures to upload,If anyone wants to see the pic PM me.
Old 06-03-2010 | 06:51 PM
Thanks for the info and link.
Old 06-09-2010 | 03:45 AM
iselloil's Avatar
The gun is from harbor freight, and is a 1.4 tip. I wetsanded the one run I had,then wet sanded the whole thing with 1000 grit paper.Then hit it with the DA sander with 220 paper, and sprayed a second coat.Interlux recomends two coats.Came out pretty good and the paint is self leveling as stated by the MFg.Its not a mirror finish but came out better than expected.[url]
Old 06-09-2010 | 04:53 PM
iselloil's Avatar
pics uploaded
Old 06-09-2010 | 04:58 PM
iamsuperbleeder's Avatar
looks good!
Old 06-09-2010 | 05:05 PM
iselloil's Avatar
This was no sanding or buffing.
Old 06-09-2010 | 05:12 PM
Swimmerboy2112's Avatar
Looks good, im gonna do my 86 4Runner top black.
Old 06-09-2010 | 05:58 PM
Zelephant's Avatar
Glad the yaht paint worked out good for you! Nice job!
Old 06-10-2010 | 01:34 AM
iselloil's Avatar
Thanks Zelephant for all the tips on using the paint.The guys at Jamestown dist. were good to deal with.They have a good post on youtube for the aplication of the paint.
Old 06-20-2010 | 12:13 PM
iselloil's Avatar
Put the topper on the truck,gave it one coat of wax and I'm done.
Old 06-20-2010 | 01:01 PM
iselloil's Avatar
camper
sunday bump
Old 06-20-2010 | 01:31 PM
helidriver's Avatar
hey i'm thinking of doing the same thing to my whole runner...... what's the parts list?
sprayer, air hose, ? size compressor?, sander, how much does the paint cost per qt/gal??
Old 06-20-2010 | 03:00 PM
iselloil's Avatar
Check out Zelephants post.He did the roll on,I as listed above,sprayed mine.I then bought a gravity feed sprayer from Harbor freight,Bought the Interlux topside paint and thinner from Jamestown distributors. I thinned it 10% with the interlux thinner.The compressor was a sears with a water filter,set to 65 lbs of pressure and then adusted the gun to 45lbs.The camper shell used less than half a quart.
I used a dewalt D.A electric sander to prep the surface with 220 grit paper.Then used lacquer thinner to wipe it down before I sprayed it.
Sprayed one coat and it turned out great. They recommend two coats when spraying.I sanded it again with 220 to take the gloss out,then sprayed again.
If it was my truck,I would have wet sanded it.But for the topper,it will do fine.
Old 06-20-2010 | 05:42 PM
Zelephant's Avatar
Did I hear my name?
Here's my Interlux roller paintjob thread:
https://www.yotatech.com/forums/f116...thread-210480/
Hope it helps!
Quick Reply: Painted the campershell
