P/N's for starter
P/N's for starter
Since I had the trans out with the clutch job I figured I'd pull the starter and see what it needs. I cleaned it up and so far it looks pretty good for a vehicle with over 300,000 mi. From what I can see, I'll replace the contact on the battery side but there are a couple of other items I'd like to replace as well.
First is a plastic post post cover for the other contact.
Second is what appears to be rubber nipple for venting or drainage?
If someone could provide some P/N's for those would be greatly appreciated.
Thanks in Advance!
d.
Battery side post contact
Plastic post cover-disintegrated
Hole and rubber nipple
Rubber nipple for vent or drain?
Thanks in Advance!
d.
As far as I know, those parts are not listed separately in Toyota's parts catalog, they only come as part of the Solenoid assembly (or magnet switch as named by Toyota).
Maybe there is someone selling these type of parts somewhere?
jener8tionx
08-08-2011 07:10 PM
Jason B
06-06-2011 05:46 PM
